Best Ways to Soundproof / Sound deaden Your Campervan
Traveling in a campervan is a leisure activity that helps you wind down outdoors and commune with nature.
A campervan is like a mini home that you travel in everywhere you go. It is all-in-one; it gives you shelter and bed-and-breakfast. It has a bed, a fridge, a fan, and the basic amenities that make your stay on the road fun, memorable and comfortable. (Learn how to plan and design your campervan layout)
But even with a fully stocked campervan, there is one small detail that can make your road life unbearable. And this is nothing other than noise. Or should I say a rattling van that offers no protection or insulation from all kinds of road/outdoor noise.
A noisy campervan rattles with every movement on the road. It reverberates with the unevenness of the road and receives all the engine and outside/neighbourhood noise, giving you a bad travel experience. It will make you (travellers, more especially the children) cranky and irritable, thereby making your whole road experience unbearable and unmemorable.
What brings about this?
A noisy or rattling campervan results from the shaking or vibration of the thin steel body of your car when it's moving on the road. These thin sheets vibrate and resonate with any movement of the car on the road. And this makes the panels produce a rattling noise.
This problem is more prevalent in older vehicles that are travelling on bumpy roads. The higher vibrations, the more your campervan becomes noisy.
The thin body of the car also offers little or no resistance/insulation to external noise. So, if you are in a noisy place or in the wild at night, any animal or party noise will infiltrate your campervan, making it loud.
To prevent the occurrence of a rattling and noisy ride, you need to sound deaden or soundproof your car.
Soundproofing your camper van is easier than you think. It will help you travel in comfort and keep the outside noise out. Soundproofing your van will help you rest in peace, travel in silence, help you focus, and will improve the effectiveness of your internal sound system.
Areas you should soundproof
Roof
The roof is the recipient of all-weather elements. It receives the brunt of rain, hailstones, and strong wind. When these elements land on the roof of your campervan, they produce an irritating sound that makes it hard for you to sleep and drowns out your conversation or stations you are watching or listening to.
Walls
Campervans have thin steel walls. This makes it easy for any noise or external sound to enter the interior of your car. These walls also produce rattling sounds when on the road. Soundproofing these walls is the best way to do away with the noise.
Doors
Car doors (driver, passenger, back, and side doors) produce a lot of road sound, especially if they are not shut well or if there are cracks between the doors and vans and around the window.
Best products or materials for soundproofing your campervan
The soundproofing materials you use should be thin and lightweight. They shouldn't take up too much space and add weight to your campervan.
Dodo dead mat
This is the sound deadening material that I used. And I found it to be an excellent way of soundproofing my campervan.
Dodo dead mat is a superior self-adhesive, foil-backed sound deadening vibration damper. It reduces unwanted vibrations and structural noise.
RoadBlockR
This sound deadening material is in the form of a thin, lightweight sheet that effectively deadens sound in a campervan.
Silent Running SR-500
This soundproofing coating absorbs both sound and vibrations in a campervan. You can apply it on metal (steel surfaces like doors and walls), fibreglass, and some plastic surfaces in your campervan.
Quiet barrier
This soundproofing material comes in many variations: high-density soundproofing sheets, sound-absorbing acoustic quilts, and peel-and-place tape. It is also easy to clean.
Mass loaded vinyl
It is an excellent sound barrier for vibration, sound dampening, and heat. Mass-loaded vinyl is also a great sound deadening mat because it also improves the inside sound.
Acoustic foam
This soundproofing material absorbs excess sound and improves the acoustics in your campervan. It is excellent for hard surfaces like the walls and roof of your van.
Butyl sound deadener mat
This soundproofing material comes as a butyl sheet with an aluminium foil layer at the back. It absorbs unwanted rattling (rattles) and vibrations.
The butyl sheet is made of butyl rubber, which makes it great at absorbing vibrations and sound waves when driving. An excellent example of the butyl sound deadener mat is the Dynamat sound deadener.
Sound Deadener insulation
The sound deadener insulation is closed cell foam wrapped or covered by foil. It is a combination of sound deadening and thermal insulation.
It is an excellent soundproofing material because it is heat resistant, durable, flexible, self-adhesive, making it easy to install as it easily moulds to the vehicle's surfaces.
Calmat automotive sound deadening mat
This butyl mat and foil mat absorb engine noises, vibrations, metal rattling, and outside noise. Its internal and external noise deadening makes it one of the best campervan soundproofing materials.
Sealants
Yes. Sealants play a big role in soundproofing. Use sealants to block cracks and any spaces around doors and windows, and panels. This will block sound from entering through the cracks.
Things to consider when choosing a sound deadener
Effectiveness of the mat in blocking or absorbing sound and vibrations
Ease of installation of the material
Level of heat resistance of the material
Material's sound-enhancing qualities on the inside of the campervan
Procedure for soundproofing your campervan
Strip your camper van panels. You can use a drill to do this.
Clean the steel sheets with an alcohol solution and leave them to dry.
Peel off the outer covering on the dodo mat sheets
Apply the dodo mat or any other sound deadening material
Stick it to the interior steel panels of your campervan
Use it to cover as many metal sheets as possible
With this guide, you now know the best way to soundproof your campervan.
A well-soundproofed campervan shouldn't block out all external sound. It should leave room for you to hear important sounds like that of cars approaching, braking, and so on. That aside, it will help you enjoy your travels in peace.
Learn more from this in-depth van conversion course about how to adequately insulate your van. You will find that it is not that hard!
