DC to DC Charger Sizing Calculator
Calculate the correct size DC to DC smart charger to buy for your campervan.
Detailed Information & Assumptions
Finding Alternator Voltage
To determine your alternator’s voltage, follow these steps:
  1. Start your vehicle’s engine.
  2. Use a voltmeter set to DC voltage to measure the voltage across your vehicle’s starter battery.
  3. If your vehicle uses a 12V system, the voltage reading should be between 13.5V and 14.5V. For a 24V system, expect a reading between 28.8V and 29.4V.
Finding Alternator Current Output
Determining the alternator's current output can be crucial for choosing the right DC to DC charger. Here’s how you can find it:
  1. Check the label on your alternator, which usually lists its current rating in amps (A).
  2. If the label is not visible or legible, search for the alternator’s part number online or consult your vehicle's manual.
  3. For convenience, you can also use online parts databases such as Euro Car Parts (for UK and Europe) or Parts Geek (for the US) by entering your vehicle's registration number.
Below is a table suggesting alternator current outputs for various vehicle types:
Vehicle Type
Example Models
Typical Alternator Output (Amps)
Large Vans
Mercedes-Benz Sprinter, Ford Transit
130A - 180A
Heavy-Duty Vans
Fiat Ducato, Renault Master
180A - 250A
Medium Vans
Volkswagen Transporter, Mercedes-Benz Vito
90A - 130A
Small Vans
CitroĂŤn Berlingo, Ford Transit Connect
70A - 90A
And here is a table suggesting alternator current outputs for various van models:
Van Model
Engine Size
Alternator Size (Amps)
Ford E-Series (E-350)
5.4L V8 Gasoline
130A - 160A
Chevy Express/GMC Savana
4.3L V6 or 6.0L V8
145A - 160A
Nissan NV3500
5.6L V8 Gasoline
130A - 170A
RAM ProMaster
3.6L V6 Gasoline
180A - 220A
Mercedes Sprinter
3.0L V6 Diesel
200A - 220A
Mercedes Sprinter
2.1L Diesel (I4)
180A
Ford Transit
3.5L V6 Gasoline
150A - 200A
Ford Transit
2.0L EcoBoost
150A
Leisure Battery Maximum Charge Current
The maximum charge current your leisure battery can handle depends on the type of battery you’re using. Exceeding these values can reduce battery life or cause damage. Here’s a general guide:
Battery Type
Max Charge Current (% of Battery Capacity)
Example (100Ah Battery)
GEL
30%
30A
Lithium-ion
50%
50A
AGM
20%
20A
These values are based on manufacturer recommendations and should be checked against your battery’s specification sheet for accuracy.
Breakdown of the Calculation
When you click "Calculate," the following steps are performed:
  1. Input Collection: The alternator output current, leisure battery type, and leisure battery capacity are collected from the input fields.
  2. Alternator Limit Calculation: The calculator multiplies the alternator output current by 50% to find the maximum charge current the alternator can safely support.
  3. Battery Limit Calculation: The battery capacity is multiplied by the maximum charge current percentage based on its type (20% for AGM, 30% for GEL, 50% for Lithium-ion) to determine the maximum charge current the battery can safely handle.
  4. Charger Recommendation: The calculator compares the alternator and battery maximum charge currents and recommends a charger size based on the lower of these two values.
For example, if you have a 100A alternator and a 100Ah Lithium-ion battery:
  • The alternator limit would be 50A (100A * 0.5).
  • The battery limit would be 50A (100Ah * 0.5).
  • The recommended charger would be a 50A charger, but since charger sizes are typically standardized, the calculator would suggest the nearest available size, such as 40A or 60A.
Wire Sizing Recommendations
Choosing the correct wire size is essential to ensure safety and efficiency. Use the table below as a guide for selecting the appropriate wire size based on the charger's amperage and the distance from the alternator to the leisure battery:
Charger Amperage
Distance (Up to 3 meters)
Distance (Up to 6 meters)
Distance (Up to 9 meters)
40A
10 mm²
16 mm²
25 mm²
60A
16 mm²
25 mm²
35 mm²
20A
6 mm²
10 mm²
16 mm²
Temperature Effects on Charging Efficiency
Temperature can significantly impact the efficiency of your battery charging system. In warmer climates, batteries may not charge as efficiently, and extreme cold can slow down the charging process or even prevent charging altogether.
To optimize charging performance, consider using a charger with temperature compensation, which adjusts the charging voltage based on real-time temperature readings.
Parallel and Series Battery Setups
Understanding how batteries are connected in your system is crucial for selecting the right charger. Here's a quick overview:
  • Series Connection: Increases the overall voltage while maintaining the same capacity (Ah). For example, two 12V 100Ah batteries in series will give you 24V 100Ah.
  • Parallel Connection: Increases the overall capacity (Ah) while maintaining the same voltage. For example, two 12V 100Ah batteries in parallel will give you 12V 200Ah.
Ensure your charger is compatible with your battery setup to prevent overcharging or undercharging.
Maintenance Tips for Batteries and Chargers
Proper maintenance of your batteries and charger can extend their lifespan and ensure consistent performance:
  • Regularly check and clean battery terminals to prevent corrosion.
  • Ensure your charger is installed in a well-ventilated area to avoid overheating.
  • Use a battery monitor to track charging cycles and battery health, helping you identify potential issues early.
  • Periodically check the charger’s settings and connections to ensure they are functioning correctly.
Common Mistakes to Avoid
Here are some common mistakes to avoid when sizing and installing your DC to DC charger:
  • Undersizing the Charger: Choosing a charger that is too small for your system can lead to prolonged charging times and inadequate power.
  • Ignoring Voltage Drop: Not accounting for voltage drop over long cable runs can result in your battery not receiving enough charge.
  • Incorrect Wiring: Improperly sized wires or incorrect connections can cause safety hazards or damage your system.
  • Overlooking Environmental Factors: Failing to consider temperature or altitude effects on charging efficiency can lead to system failures.
If you encounter any issues, such as your battery not charging fully or your charger overheating, consult the manufacturer’s troubleshooting guide or seek professional assistance.
Additional Considerations
When selecting a DC to DC charger, consider these additional factors:
  • Powering Devices While Driving: If you plan to run devices while driving, the charger needs to be powerful enough to charge the battery and run your devices simultaneously.
  • Future Upgrades: If you plan to upgrade your battery or add more electrical components in the future, it may be wise to choose a slightly larger charger now to avoid needing to upgrade later.
Always consult with a professional or refer to your vehicle and battery specifications to ensure you’re making the best choice for your setup.
