Dometic S4 Window Review & Installation Guide [With Step-by-Step Instructions]
Aug 18, 2025
15 min read
You'll most likely be installing at least one window in your van if you're converting from scratch. Indeed, our 2023 Roaming Home study found that 87% of van converters installed a window, making it by far the most common addition to a van's exterior. We just installed a Dometic S4 window in Shane's new van, Elvis. We chose the Dometic S4 for its double-glazed, insulating construction, its versatile sliding shades, and for Dometic's reputation for build quality and features. In this Dometic S4 window review, we'll look at the new window in detail and show you how we installed it, step-by-step.
Shane is an NCC-certified electrical installer.
He has built, taught, and lived in campervans since 2019.
Prefer watching? Check out our video on the installation of the Dometic S4 window:
Before starting your Dometic S4 window installation, make sure you have the following:
bosch power drill
A power drill of at least 500W For driving and drilling
bosch jigsaw
A jigsaw For cutting the hole in the van, and for cutting the wood for your frame
hss drill bits
HSS metal drill bits For drilling holes in your van's metal walls
bi-metal hole saw
25mm bi-metal hole saw bit For cutting the round corners of the window hole
bosch screwdriver set
Screwdriver bit set For screwing together your windowframe
bi-metal jigsaw blades
Metal cutting saw blades Necessary for cutting metal
sikaflex 522
Campervan sealant Sikaflex 522 is our preferred flexible, weather-resistant silicone sealant
sealant gun
Sealant gun For applying sealant
metal file
Metal file For filing away burrs on cut metal edges
anti-rust zinc metal spray paint
Anti-rust zinc mental spray paint For protecting bare metal from future rusting
white spirits
White spirit For cleaning paint brushes, excess metal paint, and excess sealant
wd-40
Tapping and cutting fluid Lubricates metal and dissipates heat whilst using the hole saw
sandpaper selection
Sandpaper For sanding cut wood
painter's tape
Painter's tape For protecting your van's paintwork during metal cutting
tape measure
Tape measure For measuring wood and metal
wood screw assortment
Assortment of wood screws For screwing the window frame together
gorilla glue
Wood glue For securely bonding the window frame
wood battens
200cm of wood batten of the right dimensions for your wall thickness For building the window frame
corner clamps
Corner clamps For holding wood in place at a 90 degree angle
d-clamps
D clamps For clamping wood during cutting
ear protection
Ear protection Sawing metal is very loud; protect your ears
What's in the Box?
In the box, the Dometic S4 is mostly put together and ready to go. The window comes in two parts: the exterior part is comprised of the outside frame and double-glazed window glass. The interior part includes the inside frame, integrated blackout blind, and integrated fly screen. Dometic supply screws for joining these two halves together, with no need to drill anything yourself. You also get little covers for the screw holes, which give a nice finish once everything's in place.
dometic s4 window product image
The instructions included with your window kit are fairly basic, and require some interpretation to understand exactly what Dometic want you to do. This has been our only major complaint with the Dometic products we've installed in Shane's van.
Key Specs
Dimensions: 500mm x 450mm
Weight: 5kg
Material: Double glazed acrylic with slight tint
  • Built-in reflective blackout blind and fly screen
  • Friction hinges allow opening of window and blinds to any position
dometic s4 review header image
Dometic S4 Size and Format Variations
This article is going to focus on the installation of the 500mm x 450mm sliding window variant of the Dometic S4, which we put in the rear door of Shane's new van. Dometic make a hinged version of the S4 window, and in a variety of sizes which suit all kinds of installations:
Dimensions (mm)
Opening Type
Dimensions (mm)
Opening Type
500 x 300
Hinge and sliding
900 x 450
Hinge and sliding
500 x 350
Hinge only
900 x 500
Hinge and sliding
500 x 450
Hinge and sliding
900 x 550
Hinge and sliding
500 x 500
Hinge only
900 x 600
Hinge and sliding
550 x 550
Hinge only
1000 x 450
Hinge only
600 x 500
Hinge and sliding
1000 x 500
Hinge and sliding
600 x 550
Hinge only
1000 x 600
Hinge and sliding
600 x 600
Hinge and sliding
1000 x 800
Hinge only
700 x 300
Hinge and sliding
1100 x 450
Hinge and sliding
700 x 400
Hinge and sliding
1100 x 550
Hinge only
700 x 450
Hinge and sliding
1200 x 300
Hinge only
700 x 500
Hinge only
1200 x 500
Hinge only
700 x 550
Hinge and sliding
1200 x 600
Hinge and sliding
700 x 600
Hinge and sliding
1300 x 600
Hinge and sliding
750 x 600
Hinge and sliding
1450 x 550
Hinge only
800 x 350
Hinge and sliding
1450 x 600
Hinge and sliding
800 x 450
Hinge and sliding
1450 x 700
Hinge only
900 x 400
Hinge and sliding
1600 x 600
Hinge only
We also installed a 1000mm x 500mm sliding Dometic S4 in the side of the van. The installation procedure and functionality of the bigger window is exactly the same as for the small window.
dometic s4 1000mm x 500mm installed in the sliding door of a van
We went with the 1000mm x 500mm Dometic S4 for the van's sliding door - it fits well, and the installation is the same.
Dometic S4 Alternatives
We were happy to go with Dometic for both the windows because we were confident in their reputation and happy with the range of available sizes. Outside of the UK and Europe, Dometic gear can be hard to source. We can happily recommend Tern Overland's hinged windows as an alternative. They're priced competitively against Dometic's offerings, with a similar range of sizes and the same feature set and reputation for quality.
First Impressions
Out of the box, the build quality that Dometic are known for is obvious. The window glass is clear, sturdy, and fetchingly tinted. The sliding mechanism feels good, locking in position through friction without ever being hard to slide. The window slides open and closed in an aluminium rail, which has flanges that overlap the frame and which contain rubber seals. The seal between the sliding and fixed portions of the window is soft foam rubber, which feels very solid and produces a soft hissing sound as the window opens and closes. Overall, the sliding mechanism and seals inspire a lot of confidence.
dometic s4 before installation
The Dometic S4 comes in two main pieces, and installation is comparatively simple
The whole thing is lightweight, at only 5kg, but feels very solid in its construction. In all our playing with the window, nothing felt sticky, flexy, or flimsy. All the mechanisms worked intuitively and smoothly, giving an overall feeling of quality that's very satisfying.
With the window installed, the mechanisms all come together. The inner frame contains the ingenius hybrid blackout blind and bug screen system. These are two sheets of material which slide up and down on rails like a Velux blind. The bug net is a fine black mesh that lets in plenty of light, and the blackout blind is backed with reflective material for keeping heat out. Each of these blinds can be smoothly opened and closed on their own using the intuitive clasp system.
The clever part reveals itself when you slide one blind until it touches the other, at which point the clasp links the two together. Now, with one movement, you can extend the one blind whilst retracting the other, setting your window to 50% blackout, 50% bug screen, vice versa, and any combination in between. It's a simple, easy to use system that allows you to get the most out of your window. I've previously dealt with the hassle of installing custom bug netting and curtains to complete a van window. It was brilliant to install something so self-contained, knowing that the job only had one step.
dometic s4 demonstration of blind function
The adjustable bug net and blackout blind are a standout feature of Dometic's windows; it really does work a treat.
From the outside, the sleek, flush-mounted and factory-finish style looks like it was built into the van from day one. The dark tint of the window itself looks premium and offers noticeable privacy from the outside. From the inside, the window's soft cream finish will go well with interior finishings, especially the wood panelling we've got planned.
dometic s4 exterior shots collage
The window looks great once installed, subtly making the outside of your van pop.
Having driven around with the window fitted for a while, we've heard no rattling and the window and blinds stay in the positions you fix them in. In the end, the most impressive thing about the Dometic S4 sliding window is that it just works. The quality-of-life features are well-built and thoughtfully implemented; nothing feels superfluous or overdesigned. Overall, we're very happy with the installation, and feel comfortable recommending it to any van builder looking for a fully-featured window that will last as long as their van does.
shane dometic s4 review testimonial
How Easy is it to Install the Dometic S4 Sliding Window?
The only complaints we had about the Dometic S4 came up during installation. These were to do with the complex instructions, and the need to construct our own frame.
The Dometic S4 is designed for installation in vans with walls that are 26mm. This is a standard wall thickness for caravans and motorhomes. If your walls are thinner than this (for example, if you're installing the window directly in the sheet metal of a panel van's walls), you need to build your own frame. If your walls are thicker than 26mm, you'll instead need to cut and install your own spacer strips. Dometic do provide measurements and instructions for these frames and spacers, but we found the installation diagrams difficult to interpret and felt like we were guessing our way through the process. The instructions below detail the procedure we came up with.
The frame or spacers need to be precisely measured and cut, and a square frame is best built with corner clamps. Thus, you'll need a bit of equipment and know-how to install your Dometic S4 if your walls aren't exactly 26mm thick. Of course, installation also requires you to cut into the wall of your van, but this is relatively straightforward. Overall, the whole thing took us 4-5 hours.
dometic s4 installation process detail shots
Building the wooden frame and cutting the hole in the van are the most challenging parts of the installation, but are easily manageable with the right tools.
The one big tip we have for installing a Dometic S4 window is: when building the wooden frame, choose wood that won't overhang the interior window frame.
The width of the space between the window hole and the outside of the interior window frame is about 2cm. We used battens which were 3cm wide, and which stick out about 1cm past the interior window frame. This meant that our wooden frame was bigger than the space in the van's panelling that the window is designed for. We had to do some very finicky adjustments to the wooden frame to get this to work. Next time, we'd choose wood which fit exactly flush with the edge of the interior window frame.
dometic s4 installed showing frame corner overlap on van interior
You can see that the corners of our wooden frame overlap the metal panel in the van that the window is build for. We had to sand indents into these corners to make sure everything fit flush.
The Van Conversion Mastery Course gives you a clear, step-by-step system to design and build your van from start to finish — without the guesswork.
How to Install the Dometic S4 Sliding Window: Step-by-Step Guide
Step 1: measure and cut the wood for your frame or spacers
Your wooden frame needs to be made of wooden battens that are of the thickness specified in the tables provided in the instruction manual. For van walls 1-2mm in thickness, these battens must be 25mm thick. As explained above, choose battens whose width won't jut out past the interior window frame.
Your wooden frame should fit snugly around the flange on the exterior window frame, and so its internal dimensions need to match the external dimensions of this flange:
Dometic s4 detail shot showing the edges of the flange which need to be measured
A precise measurement of the exterior dimensions of this flange is essential for a good fit and a tight seal around your window.
The Dometic S4 comes in multiple different sizes, so measure the flange on your model thoroughly. If you're using simple butt joints, as we did, you'll need:
  • two lengths of wood whose length matches the horizontal length of this flange
  • two lengths of wood whose length matches the vertical length of this flange + 2x the thickness of the wood
This is because the longer pieces of wood need to fully overlap the ends of the shorter pieces:
wooden window frame for dometic s4 showing measurements
Double check all your measurements and the lengths of your wood before cutting and building the frame.
If you're using mitre joints, you'll need:
  • two lengths of wood whose length matches the horizontal length of this flange + 2x the thickness of the wood
Cutting the ends off these lengths of wood at a 45° angle will give you a frame that fits over the flange.
Measure the flange on your window, calculate the lengths of wood you'll need to cut, measure and mark your wood, and clamp it to your worktop. Use a saw to cut the wood to size, and sand the cut ends to remove splinters.
detail shot showing mitre saw use for cutting frame
A mitre saw is by far the most capable tool for making clean, precise cuts in wood.
Step 2: build the frame from your lengths of cut wood
Use corner clamps to set the wood up in the form of your frame. Don't tighten these all the way down yet; keep some wiggle room between the lengths of wood whilst holding the structure in place.
using corner clamps to fix a wooden frame in place for gluing
Corner clamps are the best way of getting precise 90 degree corners in your frame
Squeeze wood glue onto the butt ends of the shorter lengths of wood, seat them flush against the longer lengths, and clamp them into place. Don't bear all the way down on the clamps one at a time, as the tension on one joint can pull the others out of position. Instead, get each clamp mostly tight, ensure everything's aligned, then go back around and tighten the clamps all the way.
squeezing wood glue onto butt ends of wood battens
Dry fit the battens in the corner clamps before glueing to make sure everything sits correctly, then lift the battens out individually for gluing.
Because the outside of this frame is going to be hidden in the walls on Shane's van, we decided to secure these joints with screws. If you decide to do this, drill pilot holes first to prevent splitting of the wood before driving the screw home. An impact driver counter sinks the screws without needing to use a counter sink drill bit first.
detail shots showing pilot hole drilling and subsequent screwing
It's best to drill pilot holes before screwing into wood, especially near the ends of narrow battens which are likely to split.
With the wood glue in place and the screws in, leave the frame clamped together for your glue's specified setting time.
Step 3: measure for the hole in your van
Once the glue's set, unclamp the frame and take it out to your van along with:
  • painter's tape
  • tape measure
  • non-permanent marker or pencil
  • drill with 25mm hole saw attached
  • tapping and cutting fluid
  • metal paint
  • paint brush
  • jigsaw
  • metal file
Set the wooden frame against the inside of your van where you want the window to be. Check that both the inner window frame and the outer window frame have room on all sides to sit flush against the van.
This is where we hit a snag: the corners of our wooden frame overlapped the inner flange of the van's rear window panel:
detail of wooden window frame showing corner overlap
Again, we made an error with our wooden frame, choosing wood that jutted out past the interior window frame and which was too big for the installation location.
This sort of thing is hard to predict without making very precise measurements and visualising everything in your head beforehand. Because we'd put screws into the ends of the joints, we weren't able to just slice off those troublesome corners. Instead, we used an orbital sander to shave an indent into the corners until the frame fit flush against the van:
using a random orbital sander to make indents in the wooden frame
We used an orbital sander to make indents in the corners of the frame. A router would have been more accurate and taken less time.
With the frame sitting flush and where you want it, it's time to mark out the hole for your window. Dometic's instructions specify that you should measure 12mm (half the diameter of your hole saw) inwards from the wooden frame and mark where these lines intersect at the corners. These marks are the locations for your hole saw cuts.
screengrab of dometic instructions for measuring and cutting hole saw holes
Dometic's instructions are fairly clear here: the hard part is taking these measurements accurately.
We found this measuring to be the trickiest part of the whole installation. In the end, we followed the following steps:
  • hold the wooden frame tightly against the van
  • very precisely trace the inside of the frame onto the van with a marker pen
  • verify that the traced line has the exact same internal dimensions as the wooden frame (this took us a couple of tries)
  • measure and mark lines 12mm in from the traced line near all 4 corners
  • the four intersections of these lines, inward from the corners of the traced line, are your hole sawing points
Step 4: cut the hole for the window
Get your ear protection on and, using an HSS drill bit for pilot holes and a 24mm bi-metal hole saw for the main hole, cut holes at the marked points. Use tapping and cutting fluid to lubricate the hole saw, and use a pulsing action to minimise heating.
using a hole saw to cut the corners for the window hole
Hole saws can get hot: make sure yours is bi-metal, and use libricant and a pulsing action to dissipate heat.
You'll be connecting these four holes with straight jigsaw cuts, and the end result will be a rectangular hole with rounded corners. On the outside of the van, carefully lay painter's tape in straight lines between the outside edges of the holes. This tape will be the guideline for your cutting.
When cutting with a jigsaw, use a low setting and move slowly and steadily. High saw speeds cause heating, warping, and breakage of the blade. Pushing too much with the saw causes it to snag and jump, making for a jagged cut and broken blades.
using a jigsaw to jut the hole in the van
Patience is the key when cutting with a jigsaw: use a low setting and don't rush to ensure a smooth cut.
Step 5: file and treat the edges of the hole
Peel off the painter's tape, and wipe away loose swarf and metal dust with a rag. Use a metal file to file down the perimeter of the hole until it's smooth and free of burrs. Take a moment to sweep or hoover up any metal shavings on the inside of the van.
using a metal file to clean the edges of the hole
Metal shavings, burrs, and swarf rust very quickly. Remove them assiduously to protect your metalwork.
All cut metal needs to be treated to prevent rust. We used white Hammerite metal paint, but anti-rust zinc spray dries more quickly and is easier to use. Apply it all around the cut metal edge, ensuring full coverage.
applying hammerite metal paint to the edge of the cut hole
Anti-rust paint is the best way to protect cut metal from rust.
Let the paint dry before moving on to the next step.
Step 6: apply sealant to the outer window frame
Per Dometic's instructions, run a thick bead of campervan sealant along the groove under the outer window frame's rim. Be liberal in your application of sealant, ensuring the bead is consistent all the way around, with no gaps.
applying sealant all around the edge of the external window frame
A consistent, thick bead of sealant all around the groove in the exterior frame will ensure your window is watertight.
Step 7: fix the two window halves together
Press the outer window frame into the hole in the van and squeeze around the edges. On the inside of the van, put the wooden frame in place around the outer frame's flange. Finally, fit the inner window frame around the flange, over the wooden frame. Make sure everything fits correctly and that the inner frame's screw holes are engaging with those of the outer frame.
screwing the window halves together around the wooden frame
Screw the corners in first, ensuring they bite and pull the window halves together. Next, do the edges, and finish off by tightening all the screws all the way down.
Due to the curvature of the van's walls, the outer frame is unlikely to fit flush at first. As you drive the screws from the inside, they should bite into the outer frame and pull it inward as they tighten down. For this reason, it's best to drive the corner screws first, and only tighten them to 70% or so. Next, drive the screws along the edges of the frame, also only to 70%. Once all the screws are in and pulling the frames together, you can go around screwing them to full tightness.
Step 8: finishing touches
Once you're happy with the fit of your window, insert the little screw hole covers all around the inside frame. On the outside of your van, check on the sealant. It's likely to have been squeezed out around the frame as everything was tightened down. A squeegee tool or wet fingertip is perfect for smoothing this extra sealant around the edge of the window frame. Give everything a final clean with paper roll or a microfibre cloth, peel the protective plastic film from the window panes, and admire your handiwork.
dometic s4 final installation from the inside
The Dometic S4 looks great once the installation's finished.
We've been very happy with the Dometic S4 window. Once installed, it looks sleek and clean, blending seamlessly with the outside of the van. The construction is solid, and all the moving parts operate cleanly with a solidity that inspires confidence. The installation isn't the easiest, however, and we'd have much preferred an installation that required the cutting of simple square corners, rather than rounded ones. Despite this, if you feel your measurement and DIY skills are up to the task, you'll struggle to do better than the Dometic S4.
For more information on windows, including a full breakdown of opening types, key paramaters, and a buying guide, check out our comprehensive article. Your next job might be the installation of a roof vent: we've got a guide on that, too, as well as an in-depth review of Dometic's excellent Mini Heki skylight. We also have an in-depth review of Dometic's FanTastic Breathe roof fan, which, along with a window and skylight, completes the ventilation system in Shane's new van.
The Van Conversion Mastery Course walks you step-by-step through the entire build process — from planning and layout to electrics, insulation, water, gas, carpentry, and more.
