Solar Charge Controller Buying Guide (Updated for 2026)
May 12, 2025
13 min read
Updated: Apr 5
Solar panels are the main power source for most off-grid campervans, but they can't do it alone. A solar charge controller takes the raw energy from your panels, packages it up, and sends it to your leisure batteries as a consistent, organised stream of electricity. At minimum, a solar charge controller keeps your batteries safe and extends their lifespan. The best models intelligently negotiate between panels and battery, maximising solar charging efficiency and charging your campervan solar power system in record time.
This guide helps you choose the best solar charge controller for your system. We'll start by looking into the difference between a budget-friendly PWM charge controller and a high-efficiency MPPT charge controller. Then, we'll calculate charge controller size and cover key specs like efficiency, built-in Bluetooth, and safety features. At the end, we'll shortlist our favourite devices, including PWM models, MPPTs, combined DC-DC and MPPT units, and easy-to-install solar kits.
solar charge controller buying guide header image
If you're just getting started, make sure you read our full guide on campervan solar systems. In that article, we go in-depth into how exactly solar charge controllers work, as well as how they integrate into full solar systems and how to wire them up.
If you want to skip the details and get your solar system ordered, these are our top picks for a solar charge controller. They're both MPPTs, boasting exceptional efficiency ratings and optimising performance even when your panels are partially shaded. They're Bluetooth-enabled, which is essential for easy monitoring, and both incorporate a full set of safety features.
Best Solar Charge Controller for Small Systems
For single panels up to 250W or series setups up to about 350W (depending on configuration), the 100|30 SmartSolar Victron MPPTĀ is an easy sell. It has built-in Bluetooth, yet beats competitors without this functionality on price. Victron's pedigree and long warranty makes it an easy sell.
100/30 smartsolar victron mppt charge controller
100|30 SmartSolar Victron MPPT charge controller
Best Solar Charge Controller for Large Systems
For single panels up to about 450W and series arrays up to about 800W, you'll need more like 60A of charging current. In this size, we recommend Renogy's Rover 60. It has the same high efficiency rating as Victron's equivalent, the same partial shading algorithms, and the same safety features and temperature compensation, all at a lower price. Bluetooth dongle and ONE Portal monitoring compatibility seal the deal.
60A Rover renogy MPPT charge controller
Rover 60 Renogy MPPT charge controller
The Two Types of Solar Charge Controller: PWM vs. MPPT
When designing your van’s off-grid power system, choosing the right type of solar charge controller is key to ensuring your solar panels charge your batteries efficiently. The two main types, PWM (Pulse Width Modulation)Ā and MPPT (Maximum Power Point Tracking), serve the same basic purpose but operate very differently. Victron have published a very detailed document breaking down the difference, but we've summarised the key takeaways below.
The PWM Solar Charge Controller: Budget-Friendly but Limited
PWM controllers are a simple and cost-effective option. They work by connecting your solar panels directly to your batteries and gradually reducing the charging current as the battery reaches full charge (remember that a battery's voltage decreases as it charges). The catch is that a PWM charge controller can't convert between voltages, so it caps its charging current to your battery's voltage.
Let's say you're running a 12V lead-acid battery (gel or AGM), which will charge at between 13.5V and 15V. A typical 100W solar panel's voltage at maximum power (Vmp) is around 17V. A PWM solar charge controller will pull that 17V down to around 14V to match your batteries, losing power in the process. Let's see how much power we'll lose in that step-down.
Panel maximum power voltage (Vmp): 17.5V
Panel maximum power current (Imp): 5.71A
Panel nominal maximum power = 17.5V x 5.71 = 99.9W
PWM-reduced charging voltage: 14V
Panel actual charging power = 14V x 5.71 = 79.9W
That's a loss of about 20% of your panel's total power, due to the PWM controller's inability to convert between voltages. In order to not lose charging power, you'd need to be using a solar panel whose Vmp is less than 15V.
12V nominal solar panels, whose Vmp doesn't much exceed the charging voltage of 12V leisure batteries, do exist in wattages up to 150W. If you want more solar power in your system, PWM charge controllers aren't a good choice. If you’re keeping things minimal, with a small leisure battery (up to about 100Ah) and up to 150W of solar just powering lights and USB ports, a PWM controller will do the job. They're affordable, easy to install, and work well in smaller, lower-demand systems.
pwm solar charge controller close-up image
A PWM charge controller is cheap, simple to wire up, and fine for small electrical setups.
PWM Charge Controllers and Lithium Batteries
The story is reversed with lithium batteries. These typically have a charging voltage that starts at ~13.5V and tops out at ~14.5 as the battery approaches full charge. Below these voltages, lithium batteries won't charge at all. Because a PWM solar charge controller can't convert between voltages, your solar panels need to be producing at least 14V for your lithium batteries to charge. On hot days when panel voltage drops, or when charging power is very low, a PWM might not be able to hack it. For this reason, it's hard to recommend a PWM solar charge controller for any lithium battery setup.
The MPPT Charge Controller: Smarter, More Efficient Charging
MPPT charge controllers are more sophisticated. Rather than simply matching voltages, they use a DC-to-DC conversion system that tracks the solar panel’s optimal power output (maximum power point) and converts any excess voltage into additional charging current. Remember that power (W) = volts x amps: Because an MPPT can convert between voltages, it can take the solar panel's full power output, convert it to the voltage the batteries want, and supply it at a higher amperage.
large battery bank with mppt charge controller
Higher-capacity systems with large high capacity or lithium battery banks will be best served by an MPPT solar charge controller
Any solar panel above ~150W will have a higher Vmp than what leisure batteries can take. Wiring multiple panels in series also adds up their output voltage, easily putting you above this threshold. Finally, cold temperatures naturally increase a solar panel's output voltage. A MPPT charge controller is comfortable in all of these cases, dynamically converting its output voltage and current to suit your batteries.
Additionally, MPPTs have no problem stepping up their output voltage to match a lithium battery's charging threshold. This means that even on hot days or when charging power is low, an MPPT can fully charge your lithium battery.
MPPT Charge Controller vs. PWM: Which Should you Choose?
Ultimately, your decision comes down to how big your system is, your battery chemistry, what voltage your solar panels produce, how much you're willing to invest upfront.
Cost
Works with lithium batteries?
Ideal solar panel voltage
Ideal system capacity
Room for expansion?
PWM
Ā£15–£100
No
~15V
~100Ah
No, because adding solar panels in seriesincreases voltage
MPPT
Ā£35–£400+
Yes
Any
Any
Yes, because MPPTs can convert between voltages
Nick at Cleversolarpower has done a great video summary of the difference between PWMs and MPPTs:
Sizing Your Solar Charge Controller
Undersized controllers can overheat or fail, while an oversized one might be an unnecessary expense.Ā Let's break down how to size your controller correctly.
  1. Match the battery voltage
First, ensure the controller's voltage rating matches your battery bank:
  • 12V battery bank: Use a controller rated for 12V.
  • 24V battery bank: Use a controller rated for 24V.
  • 48V battery bank: Use a controller rated for 48V.
Some solar panel controllers, like Renogy's RoverĀ and Rover LiteĀ series, are compatible with multiple voltages, but always confirm this in the specifications.
  1. Calculate the maximum current
Solar charge controllers are sized according to two key figures: charge current and charge voltage. To size for current, determine the maximum current your solar panels can produce and ensure the controller can handle it.Ā Use the formula:
Current (A) = Total Solar Panel Wattage (W) Ć· Battery Charging Voltage (V)
For example, if you have 400W of solar panels and a 12V battery bank that charges at 14.7V:
400W Ć· 14.7V = 27.21A
In this case, you'd need a controller rated for at least 30A to provide a safety margin.
electrician testing a pwm charge controller installed in the back of a van
Sizing your charge controller correctly involves matching a couple of key specs to your solar array and ensures your solar system works safely and effectively
  1. Calculate the open circuit voltage (Voc)
To size for voltage, we need to look at your solar panel's open circuit voltage and choose a charge controller that can handle this Voc. If you have multiple panels wired in series, their Voc is added up. For example:
If you have two 100W solar panels wired in series which each have a Voc of 21.5V:
21.5V x 2 = 43V
  1. Account for temperature variations
Solar panel voltage increases in colder temperatures.Ā To prevent overvoltage, ensure the controller's maximum input voltage exceeds the panel's open circuit voltage (Voc) adjusted for cold conditions.Ā A common practice is to multiply the total Voc by 1.25 to account for temperature:
Adjusted Voc = Total Voc Ɨ 1.25
Using the previous example:
43V Ɨ 1.25 = 54V
Ensure your controller can handle at least this voltage.
In this case, our campervan solar power system needs a charge controller rated for 30A and 54V. Victron's BlueSolar 100|30 would do nicely: it's rated for an open circuit voltage of 100V and a current of 30A.
Victron MPPT BlueSolar 100|30
Renogy's Rover Li 30 would also be a good choice: it's rated for 30A and up to 100V.
rover li 30 renogy mppt charge controller
Renogy MPPT Rover Li 30
By carefully matching your solar array's specifications with the appropriate charge controller, you ensure efficient and safe operation of your van's electrical system. To simplify these calculations, check out our MPPT sizing calculator.
mppt sizing calculator screenshot
Our handy tool does all these calculations for you based on your solar array, and even recommends charge controllers that fit the bill.
The Van Electrics MasterclassĀ walks you through the entire system step-by-step — so you can design and install it properly, with confidence.
Key Features of Solar Panel Controllers
Now that you have your solar charge controller sized, you can start looking at specific models. What matters here is efficiency, connectivity, and safety. Let's take a look.
Efficiency and Charging Algorithms
Most modern controllers utilize a multi-stage charging process; typically bulk, absorption, and float stages, to efficiently and safely charge your batteries.Ā This approach helps maximize battery lifespan and performance. Some chargers automatically detect your battery's chemistry and change their settings accordingly, whilst others need to be set manually. Either way, make sure you look for a charge controller that works with your battery type.
Conversion efficiency is the stat that solar charge controllers trade on. The best solar charge controllers, like a BlueSolar or SmartSolar Victron MPPT or a Rover Li Renogy MPPT, are 98% efficient, meaning that 98% of the gathered solar energy is transferred to your batteries.
Safety Protections
A good solar charge controller incorporates safety features to prevent dangerous malfunctions. My van's electrics are installed under my bed; I'd never be able to sleep at night had I installed components that didn't have the following protections:
  • Overcharge protection: prevents my batteries from being overcharged, which causes overheating and impacts their lifespan
  • Over-discharge protection: Stops my batteries from discharging beyond safe levels, again preserving their lifespan
  • Short circuit and overload protection: Safeguards why whole system against dangerous electrical faults
  • Reverse polarity protection: Protects my controller and connected devices if I accidentally connect anything incorrectly
renogy dc-dc charger showing safety certifications and failsafes
Trustworthy manufacturers should advertise a comprehensive range of safety features and certifications for their charge controllers
In addition to these core safety protections, my 40A Renogy Rover Li also has good temperature compensation performance. I use my van year-round, and temperatures vary a lot. Temperature compensation adjusts the way my MPPT manages charging, maximising safety and efficiency as my system's temperature fluctuates. Look for a charge controller with its own temperature sensor and a compensation rating of -3mV to -5mV per °C per cell or –18mV to –30mV per °CĀ total.
Display, Monitoring, and Connectivity
It's important to know what your charge controller is doing. You need to be able to tell, at a glance, how much solar power you have coming in, how much is going to your batteries, how charged they are, and how quickly they're discharging. Faults need to be clearly indicated and easy to understand. The more information, the better.
The first cheap, no-name charge controller I installed in my van had a really basic screen, and I could never tell exactly how well my solar system was working. It was incredibly frustrating, and trying to fiddle with the solar charge controller settings was even worse. I eventually replaced it with a 40A Renogy Rover Li that has a big, backlit screen, which is easy to navigate and tells me everything I need to know at a glance. I'd never go back. I later added a BT-2 Bluetooth module, which allows me to do all of this from my phone.
screenshots of victron monitoring app showing whole-system status view and detailed solar performance history
Bluetooth connectivity allows you to monitor your solar system from your phone, giving you easy access to far more data than you could get from the screen on your charge controller.
We're putting a 150|60 Victron SmartSolar MPPT in Shane's new van. Victron MPPTs don't have screens, but the SmartSolar models have built-in Bluetooth modules. This allows you to monitor them and change their settings from your phone or PC. Being able to check up on your solar system on a big screen with a fully-featured app is a real pleasure, and makes changing settings and monitoring performance over time a dream. If you go with a non-Bluetooth BlueSolar, consider adding a VE.Direct Smart Dongle so you don't miss out on remote connectivity.
a testimonial from shane explaining his choice of a smartsolar victron mppt for his new van conversion
What MPPT Charge Controller to Buy? Our Favourite Models
We'll be recommending Renogy and Victron charge controllers here. I have a Renogy, and Shane has a Victron. We find these brands hard to beat on price considering their excellent efficiency ratings and advanced feature sets. Shane went with Victron for the slightly longer warranty and GX integration, whilst I went with Renogy because they're slightly lighter on the wallet. Both of us went with MPPT over PWM, as we live in our vans full-time and we're happy to pay a bit extra for maximum efficiency. MPPTs from competitors EP Solar and PV Logic have comparable efficiency ratings, warranties, and safety features, but don't manage to compete on price, so they're hard to recommend.
The Best PWM Charge Controller
For anyone installing a budget, low-capacity electricity system, a PWM charge controller can be the right choice. EP Solar's 10A Landstar PWM charge controller would work well for solar arrays up to 120W. It has comprehensive safety features, works for all lead-acid battery types, and even has a built-in USB port, so you can charge your phone directly from your solar panels.
ep solar landstar 10a pwm charge controller
EP Solar Landstar 10A PWM Charge Controller
The Solar Charge Controller for Small Systems
For single panels up to 250W or series setups up to about 350W (depending on configuration), the 100|30 SmartSolar Victron MPPT is an easy sell. It has built-in Bluetooth, yet beats competitors without this functionality on price. You also get impeccable 98% efficiency, robust temperature compensation, compatibility with Victron's GX monitoring suite, and top-of-class performance with partially shaded panels thanks to the BlueSolar algorithm.
100|30 SmartSolar Victron MPPT Charge Controller
The Solar Charge Controller for Large Systems
For single panels up to about 450W and series arrays up to about 800W, you'll need something bigger. Among 60A charge controllers, we recommend Renogy's Rover 60. In these higher capacities, the price difference between Victron and Renogy becomes apparent. Renogy's offering has the same high efficiency rating, the same adaptive algorithms for partial shading, and the same safety features and temperature compensation. It's Bluetooth compatible with a dongle and integrates with Renogy's own monitoring suite, ONE Portal.
rover 60 renogy mppt
Renogy Rover 60 MPPT
Victron's 150|60 BlueSolar, the Rover 60's equivalent, comes with Victron's standard 5-year warranty compared to Renogy's 2 years, and will integrate much better with an all-Victron GX-monitored system.
The Best Solar Charge Controller - Combined MPPT and DC-DC Charger
As we discussed in our DC-DC charger buying guide, a combined MPPT and DC-DC charger unit promises one box, one fuse set, and less wiring, saving money and simplifying your installation. It's a good option, but be wary of the way the double duty is handled. The device caps solar and alternator inputs at 25A each when both are active. This means that if your engine's running, your solar input is capped at 25A even if your panels could supply more. By contrast, with the engine turned off, your solar panels are free to supply the full 50A.
A 25A MPPT can take the input from up to about 400W of solar, which is still a lot. If you've got a solar array in this range, a smart alternator, and want to simplify your electrical system, a combined unit is worth a look. We recommend Renogy's 50A Combined DC-DC charger and MPPT here. Both the DC-DC and the MPPT component have decent efficiency ratings (though not as high as standalone units); built-in Bluetooth sweetens the deal.
renogy 50a combined dc-dc charger wiht mppt
Renogy 50A Combined DC-DC charger with MPPT
The Best Campervan Solar Kit
Your charge controller and your panels are only one part of the whole solar system. Besides the panels, you need a solar charge controller, fuses, busbars, cables, and mounting equipment for the panel. Overwhelmed? This is where campervan solar panel kits come in.
Buying your whole solar system in a kit ensures your MPPT is sized correctly to your panels, and gives you all the wiring, connectors, fuses, and mounting hardware you'll need for the installation. We can easily recommend this 450W solar kit. It's generously sized for most use cases, powered by Eurener's excellent half-cut solar panel and a SmartSolar Victron MPPT with built-in Bluetooth.
sunstore 450w solar panel kit
Sunstore 450W solar kit
You should now be fully equipped to choose among the best solar charge controllers, matching your panels and complimenting your solar system. For an overview of the other components you might need, check out the dedicated section in our solar panels buying guide. When you're ready to take the plunge, check out Victron's SmartSolar MPPTs for their overall balance between supreme quality and affordable price. Alternatively, Renogy's Rover series is a good option at in higher capacities. Or, take the hassle out of sizing and matching components altogether with a solar panel kit.
If you need more information, don't forget to take a look at our comprehensive article on campervan solar systems.
The Van Electrics MasterclassĀ shows you exactly how to design and install a safe, reliable electrical system — step by step.
