The Best Flexible Solar Panels: Our UK Buying Guide (Updated for 2026)
Nov 4, 2025
14 min read
Updated: Apr 5
If you've got a pop-top roof, if stealth is important, or if you're going for a drill-free install, flexible solar panels can be a neat, low-profile alternative to rigid solar panels. They’re wafer-thin, feather-light, mount with adhesive rather than screws, and they mould to the form of curved roofs. The trade-off is that flexible solar panels don’t match rigid panels for outright efficiency or longevity, and they're more affected by heat. That doesn’t make them a compromise too far; it simply means choosing them for the right reasons and installing them the right way.
In this guide, we’ll demystify what “flexible” really means, how today’s panels are built, and where the market sits on efficiency, weight-per-watt, and warranties. We’ll explain why heat matters, how to manage it, and how to size and wire a system that suits weekenders through to long summer tours. Finally, we'll go over the step-by-step process that Shane used to mount flexible panels to his first van.
flexible solar panels buying guide header image
The Best Flexible Solar Panels: Our Top Pick
Based on a balance between cost, published module-level efficiency ratings, and warranty length, we believe that Renogy flexible solar panels are the best overall buy. They make ultra-thin, ultra-light flexible panels using the most up-to-date materials and cell technology. They make 50W, 100W, 150W, and 200W panels, which should be sufficient to put together arrays that suit most conversions.
renogy flexible solar panel product image
What is a Flexible Solar Panel?
Flexible solar panels are thin, bendy solar panels that can flex to match gentle curves. They're very thin, typically only 2-4mm, and are thus also very light. They don't incorporate a bulky structural frame like rigid panels do, and the junction box is generally very low-profile.
renogy flexible solar panels mounted to a curved caravan roof
For curved or fibreglass pop-top roofs, flexible solar panels are often the only reasonable solution.
Due to their lightness and minimal design, flexible solar panels are designed to be mounted flush to your roof with adhesive. This means that installation is completely drill-free, and also that a flexible panel is very low-profile. They're therefore perfect for mounting on pop-top roofs, and for stealth campers where protruding rigid panels would be a dead giveaway.
shane demonstrating the thinness and bendiness of a flexible solar panel
Flexible solar panels are ultra-thin and bendy, making them perfect for stealth installations and pop-tops.
The State of the Market: Are Flexible Solar Panels any Good?
These days, the best flexible solar panels have a tough ETFE topsheet, which is very durable and doesn't crack or scratch, unlike rigid panels. It's a textured coating that resists UV much better than the PET alternative and is 'self-cleaning', meaning it doesn't collect algae or dirt.
The Effiency of Flexible Solar Panels
Modern, high-quality flexible solar panels are all high-efficiency monocrystalline (read about why this matters here) and are made of either back-contact or PERC cells. However, it's important to realise that flexible panels still aren't as efficient as rigid ones. Most manufacturers quote cell efficiency figures, but the efficiency of the whole panel, or module efficiency, is what really matters.
Renogy's 100W flexible solar panel offers a module efficiency figure of 15.7%. EcoFlow's 100W offering sits at 15.5%, and Bluetti's ultra-efficient FX series gets up to 17%. This is in comparison to module-level efficiency figures of around 20% for rigid panels. Market leading efficiency ratings can be found in high-end marine panels like those from Solbian, which get up to 17-18%, and Solara Power-M at 18.8%. Note that those extra percentage points in efficiency will cost you hundreds of pounds over more affordable panels.
solbian flexible solar panels mounted to the roof of a boat
Flexible solar panels were originally designed for the marine market, where their exceptional toughness allows them to shrug off sea spray and harsh weather in a way rigid panels will never manage.
Weight-Per-Watt
Weight-per-watt is where flexible panels shine, rather than in efficiency. Those Renogy, EcoFlow, and Bluetti panels all weigh 2.2-2.4kg, giving them weight-per-watt figures of 0.022-0.024kg/watt. High-end marine panels are even lighter; the above Solbian panel weighs only 1.4kg. By contrast, rigid panels sit at more like 0.05-0.06kg/watt: about triple the weight for the same wattage. This is usually the only kind of panel that will work on a pop-top roof, as rigid panels would make the roof too heavy to raise by hand.
renogy flexible solar panels mounted to a pop-top campervan roof
Flexible solar panels are much lighter than rigid ones, making them a very good choice for mounting on pop-top roofs which need to remain light enough to be raised manually.
Cost
Cost used to be a major point in favour of flexible solar panels, as they were often cheaper than rigid ones. However, the price of solar cells has dropped precipitously in recent years, and this is no longer the case. In fact, flexible solar panels from reputable manufacturers typically cost a bit more than their rigid counterparts.
graph showing drop in per-watt cost of PV cells as global capacity has increased
Whether you're going for flexible or rigid, it's important to not skimp on quality and buy your panels from a reputable manufacturer. On Shane's last van, he installed four 100W flexible solar panels he’d bought from Amazon; not the absolute cheapest, but still budget models. Over seven years, he watched their output steadily decline until they were producing less than half of their original rating.
We recently helped another customer who’d bought a bargain-bin solar kit from Amazon; the panels were literally wired backwards out of the box. It took a full rewire just to get them working. Cheap flexible panels might look like a shortcut, but in reality, they’re a false economy.
How Long do Flexible Solar Panels Last?
It's also worth mentioning lifespans, and comparing warranties across flexible and rigid panels tells the story. The panels discussed above all come with warranties of up to five years, with no distinction made between a materials and performance warranty. By contrast, you can expect 5-10 year materials warranties on rigid panels from marques like Renogy and Victron, with a 25-year guarantee that the panel won't drop below 80% of its original output. This demonstrates the fact that even the best flexible panels aren't as long-lasting as rigid ones. A lot of this can be attributed to how flexible panels handle heat.
We've summarised the differences between rigid vs. flexible solar panels in the table below:
Rigid Solar Panels
Thickness
30-50mm
1-3mm
Weight
0.05-0.07kg/watt
0.01-0.03kg/watt
Efficiency
19-24%
15-17% (ETFE consumer-grade) 17-19% (high-end marine-grade)
Cost
£0.70–£1.20/watt
£1.40–£2.20/watt (ETFE consumer-grade) £4–£8/watt (high-end marine-grade)
Lifespan
25 years to 80% performance
5 years to 80% performance for the most part
Heat resistance
No issues
Can cause severe issues without adequate cooling, still reduces lifespan overall
Ruggedness
Prone to scratching and shattering, can't be walked on
Resistant to scratching and shattering, many models can be walked on
The Effect of Heat on Flexible Solar Panels and How to Deal With It
Flexible panels don’t usually have dramatically worse temperature coefficients than rigid glass modules, but they operate hotter because they’re bonded flat to a roof with little or no airflow. This disrupts convective cooling: a framed panel rides above the roof in moving air, so for any given sunny day its cell temperature is lower. Flexible panels soak heat into the laminate and the roof beneath, which cuts solar output and, over time, accelerates polymer ageing. This is why flexible panels typically deliver a little less on hot days and age faster.
flexible solar panels mounted to the roof of a campervan
You can use the existing ribs and structural features on your van roof to establish airflow under your flexible solar panels.
You can mitigate this effect to an extent with proper heat management during your installation. Wherever the roof layout allows, mount your flexible solar panels on structural ribs or thick beads of adhesive to raise it above the flat surface and create a micro-air-gap. Avoid sticking them down with a continuous adhesive bed that traps heat, don’t seal every edge airtight, and use a lighter-coloured sealant-adhesive. These simple choices measurably lower cell temperature and ease (but don't eliminate) the long-term stress on the laminate and the roof. At the end of the day, however, long-term durability is the price one pays for the minimalist contruction of a flexible solar panel.
Who Are Flexible Solar Panels For?
The benefits of flexible solar panels lie in their form factor and ease of installation, rather than in their performance. Flexible solar panels are extremely lightweight, and fit flush to your roof without any drilling. Therefore, they're ideal for:
  • Pop-top roofs: a pop top can't be drilled into, and can't take the weight of rigid panels. Flexible solar panels are the only way to get a permanent, full-sized solar array on a pop-top camper.
  • Stealth builds: rigid panels sticking up out of your roof is a dead giveaway that your otherwise unassuming panel van has someone living in it. In countries that are strict on vanlife like the UK, flexible solar panels are often the only viable option for full-timers.
  • Drill-free installations: many entry-level, summer, or weekend vanlifers go for simpler builds with less permanently installed hardware. If you've no fixed kitchen, no exterior metalwork, and a stripped-back electrical system, it's very reasonable to just want to stick a flexible panel to your roof rather than drilling and bolting a framed array.
Flexible solar panels don't match rigid ones in terms of performance and lifespan, but for less hardcore vanlifers, that's just fine. If that sounds like you, read on for our recommendations on the best flexible solar panels currently on the market.
The Best Flexible Solar Panels: Our Top Picks
If you've decided that flexible solar panels are right for you, we've collected the models that we'd be happiest installing on our own vans. We've prioritised price and efficiency, with warranty length also an important factor.
The Best Flexible Solar Panels: 75-125W
Our top pick is Renogy's 100W Flexible Solar Panel. Renogy are unusal in that they're upfront about the module efficiency of their panels, which we appreciate. It stands at 15.7% for this model, which is very respectable within this price range. The Renogy panel is very light, at 2.4kg, and comes with a 5-year material and 90% performance warranty.
As a runner-up in this category, we selected Bluetti's PV100 FX flexible solar panel for its unusually high module-level efficiency rating: 17% for the 100W panel.
The Best Flexible Solar Panel: 175-225W
We found Renogy's 200W flexible solar panel to stand out among its competitors, mainly due to its published module efficiency of 16.7%. This is achieved with half-cut PERC cells, which reduce the effect of partial shading and trap additional sunlight in a multi-layered design. The 25-year 80% performance warranty is also very impressive, backing up the manufacturer's confidence in their construction and heat resistance.
renogy 200w flexible solar panel product image
The Best Flexible Solar Panel for Maximum Efficiency
If flexible is your only option and you can't skimp on efficiency, high-grade marine panels are your best bet. Solara's Power M-series top out the flexible market with 19% module efficiency, which is almost what you get from rigid panels. These panels are designed for the exigencies of marine use, so they'll withstand extreme heat, humidity, cold, and salt water, and can be walked on without issue.
solara power m-series flexible solar panels product image
The Best Flexible Solar Panel Kit
Buying your flexible solar panel in a kit saves you having to figure out which charge controller you'll need and sizing your wires and fuses. Instead, buy everything you need pre-specced and ready to install. Sunstore Solar bundle their 150W flexible solar panel with the excellent Victron SmartSolar Bluetooth MPPT charge controller, a roof fixing kit, and all the wires and fuses you need for your installation.
sunstore solar flexible solar panel kit
Sizing Your Flexible Solar Panels
As we discuss in detail in our campervan solar systems guide, sizing your solar array involves figuring out your daily electricity usage, the number of hours of sunshine you'll get each day, and the efficiency of your panels. Our energy consumption calculator is a simple way of calculating your daily electricity usage, which is also used to work out the size of your leisure batteries. Once you have this number, use our solar panel calculator to size your solar panels.
solar panel sizing calculator screenshot
Our solar panel sizing calculator makes sizing your solar array simple.
Average sunshine hours vary depending on location and can be found online. Wikipedia has a useful list of cities around the world and their sunshine hours - to find the daily average across the year, take the annual total sunshine hours and divide by 365. If you'll only be using your van for part of the year, add up the number of sunshine hours for your chosen months and divide the total by the total number of days across that period. For example:
Daily sunshine hours for London, England for all-year use =
Annual sunshine hours (1,633) / 365 = 4.47
Daily sunshine hours for London, England for 3-season use =
Sum of monthly sunshine hours for months March - October =
155 + 169 + 199 + 204 + 212 + 205 + 149 + 117 = 1,410
Sum of days per month for months March - October =
31 + 30 + 31 + 30 + 31 + 31 + 30 + 31 = 245
Average daily sunshine hours = 1,410 / 245 = 5.76
Solar panel efficiency is the amount of solar power that your panels are able to convert into electricity. Note that the important number is module efficiency, rather than the cell efficiency that's often quoted by manufacturers. The equation for calculating module efficiency is:
Module efficiency = Rated Power (W) / (Area (m²) x 1000
This equation won't give you as precise a figure as a published module efficiency figure, but it's accurate enough for use in solar panel sizing calculations.
The Van Electrics Masterclass walks you through the entire system step-by-step — so you can design and install it properly, with confidence.
Solar Charge Controllers for Your Flexible Solar Panels
We go over charge controllers in much more detail in our 2025 Buying Guide, so be sure to check that out. In brief, a solar charge controller sits between your solar panels and your leisure batteries, ensuring that your panels work efficiently and your batteries charge safely. Charge controllers come in two types; PWM and MPPT, and we always recommend MPPT. They're a bit more expensive, but they give you significant gains in terms of solar efficiency and power generation.
Charge controllers come in different capacities, and must be sized depending on the size of your solar array. Use our handy MPPT sizing calculator to figure out the size you need.
victron smartsolar mppt charge controller
How to Install Flexible Solar Panels on Your Van
Having decided on your flexible solar panels and the size of your array, let's take a look at how to install them on your van.
A Note on Panel Curvature/Flex Angle
All flexible solar panels have a maximum curvature that they're rated to by the manufacturer. For example, the above linked Renogy panels both have a maximum curvature of 240° over their whole length. Note that this is over their length, not their width. The 200W panel can flex through 240° across its length of 160cm, which means an angle of 1.5° per centimetre. Across its 75cm width, therefore, the panel could flex to an angle of 112°.
shane bending a flexible solar panel to a high angle
Most flexible solar panels can bend further than you'll ever need them to, but check that the manufacturer's recommended flex angle matches your mounting surface.
Flexible solar panels can flex multiple times along the same axis, so they can conform to an S-curve if needed. However, they should never be flexed along both their horizontal and vertical axis.
flexible solar panels conforming to multiple flex angles along the same axis
These flexible solar panels are conforming to an S-curved surface, with a convex curve and a concave curve along their longditudinal axis. This is fine, but a panel should never be flexed across both axes.
Over-flexing your panel or flexing it along two axes at the same time will damage it, so make sure you understand your chosen panel's rated curvature and don't try to make it conform to a roof shape that will damage it.
  1. Dry-fit and mark: choose where you'll install your panels, staying as clear as possible from anything that will cast shade on them. Plan where you'll install the gland that holds the cables as they enter the roof, and make sure you've got enough cable to reach this and extend at least 30cm inside. When you're happy with your mounting location, mark it with painter's tape.
  1. Prepare the roof surface. Wash and degrease the footprint where you'll mount the panels with isopropyl alcohol.
washing roof surface in preparation for flexible solar panel installation
A clean roof is essential to get a strong bond between your adhesive and your solar panels.
  1. Place the cable gland. Pick a high, draining spot close to the panel junction box and away from places water can pond. Drill and saw the hole, file the cut metal edge, paint the bare metal with anti-rust paint, and fit the gland. Check out our article on solar cable entry glands for more detailed fitting instructions.
using a hole saw and a jigsaw to make the hole for your solar cable entry gland
Hole sawing is a good way to do most of the cutting for your entry gland, even if you need to finalise the shape with a jigsaw.
  1. Choose your ventilation strategy. Because flexible solar panels run hot when bonded flat, we need to incorporate cooling from the start. If you're mounting to a ribbed panel van roof, ventilation is already in place; simply stick the panels to the ribs, and leave the channels in between free for air flow. If you're mounting to a flat pop-top roof, we need to create these air gaps ourselves. Thick beads of adhesive or adhesive tape laid in strips will adequately raise the panel above the mounting surface, creating these air gaps. Plan to leave breather breaks in the perimeter sealant bead so the panel isn’t sealed airtight.
  1. Lay out the adhesive. Manufacturers now advise against bonding flexible panels directly with polyurethane/MS-polymer sealants like Sikaflex, because they don’t adhere well to the panel laminate and they’re too stiff to accommodate thermal expansion, which can lead to delamination, bubbling, and cracked cells over time.
    applying 3M VHB tape to a flexible solar panel
    3M VHB tape is an easy way of sticking your panels to your roof and is recommended by many manufacturers.
    Instead, they specify acrylic VHB tape or structural silicone applied in strips. Exotronic, a flexible solar panel manufacturer, recommend silicone-based adhesives like Dowsil 895 and Soudal Silirub 2 or 3M VHB tape. If you're going with silicone on a flat roof, run a perimeter bead 10-12 mm in from the panel edge and add longitudinal rib beads every 80-120 mm across the footprint. Remember to leave small gaps in the perimiter bead for cooling, and don't spread out a continuous bed of sealant. If you go with 3M VHB tape, follow a similar pattern, with a continuous perimiter strip punctuated by breather breaks and longditudinal support strips in the middle.
vunked flexible solar panel adhesive diagram
Vunked recommend a single larger gap at the rear of the panel, and lateral beads which don't touch the outer bead to maintain airflow and drainage under your flexible panels. Note that they mention SikaFlex, but this is now discouraged by many manufacturers. Go with a silicone-based adhesive instead.
If you're installing your panels on a ribbed roof, the easiest method is to apply your adhesive along the ribs. Make sure the lateral edges of your panel are supported to prevent flapping or peeling: if you can't get both edges to sit on a rib, you might need to create an appropriate surface using layers of mastic tape.
Shane using 3M VHB tape along the ribs of his van's roof as the adhesive for his flexible solar panels
3M VHB tape laid along the ribs in a van's roof is the easiest method for mounting flexible solar panels to your van.
  1. Bond the panel. Lower the panel onto your adhesive. Starting from the centre, work outwards with a soft roller or the palm of your hand to seat the beads without squashing them flat; you’re aiming for a compressed bead height of a couple of millimetres, not a pancake. Wipe away any squeeze-out, and verify that your breather breaks have held. Leave the sealant to cure for the manufactuer-recommended time.
flexible solar panels mounted to ribs on the roof of a campervan
Shane used 3M VHB tape run along the ribs on the roof of his van to form spacers which promote airflow under his flexible solar panels.
  1. Wire up your panels. Feed the cables from the panels through your cable entry gland, and wire them into your solar charge controller. Check out our complete guide to campervan solar systems for detailed instructions on solar panel wiring.
You should now feel equipped to choose and install flexible solar panels for your van conversion. They're not right for everyone, but flexible solar panels might be exactly what you're looking for if you've got a pop-top roof, a stealth build, or are going for a drill-free installation. We recommend Renogy's flexible solar panels in both their smaller and larger sizes to virtually all installers. Alternatively, buy your flexible solar panels in a kit to simplify your build. If you need more information on solar systems before buying your components, our comprehensive guide should answer all your questions.
The Van Electrics Masterclass shows you exactly how to design and install a safe, reliable electrical system — step by step.
